Saltar al contenido principal
RIDGID R32104 Saw Blade Replacement
Qué necesitas
  1. RIDGID R32104 Saw Blade Replacement, Saw Blade: paso 1, imagen 1 de 1
    • Turn off your saw and unplug before starting.
    • The RIDGID R32104 Saw did not come with a blade, so paper was used to mime the actions needed.
    • Place the Worm Drive Saw on a sturdy surface.
    • The blade is located within its upper blade guard and lower swing guard assembly.
  2. RIDGID R32104 Saw Blade Replacement: paso 2, imagen 1 de 2 RIDGID R32104 Saw Blade Replacement: paso 2, imagen 2 de 2
    • Using a H-6 mm Allen Key, remove the 3/8 - 16 UNC LH screw, washer, and outer blade washer that fixes the blade in place.
    • In order to unscrew this, you must turn the screw clockwise to loosen it.
  3. RIDGID R32104 Saw Blade Replacement: paso 3, imagen 1 de 1
    • Adjust the lower swing guard to properly grab the blade.
  4. RIDGID R32104 Saw Blade Replacement: paso 4, imagen 1 de 1
    • Remove the blade by gingerly grabbing towards its center, preventing any injury from occurring.
Conclusión
Una persona más ha completado esta guía.
Lucas Pimentel
Miembro Desde 04/02/19
1,010 Reputación
8 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 24
Todo El Tiempo: 1,102
