Saltar al contenido principal
RIDGID R32104 Motor Brush Replacement
Qué necesitas
  1. RIDGID R32104 Motor Brush Replacement, Motor Brush: paso 1, imagen 1 de 2 RIDGID R32104 Motor Brush Replacement, Motor Brush: paso 1, imagen 2 de 2
    • Turn off your saw and unplug before starting.
    • Place down the Worm Drive Saw on a sturdy surface.
    • The motor brush cap is located on the side of the main housing assembly, it can be identified as a large black plastic cap with a slit running down its surface.
  2. RIDGID R32104 Motor Brush Replacement: paso 2, imagen 1 de 2 RIDGID R32104 Motor Brush Replacement: paso 2, imagen 2 de 2
    • Using a flathead screwdriver, remove the motor brush cap from the main housing assembly.
  3. RIDGID R32104 Motor Brush Replacement: paso 3, imagen 1 de 1
    • With the cap removed, the motor brush should now be accessible.
    • Carefully remove the motor brush by sliding it out of the main housing assembly.
Conclusión
Una persona más ha completado esta guía.
Lucas Pimentel
Miembro Desde 04/02/19
1,010 Reputación
8 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 19
Todo El Tiempo: 789
