Saltar al contenido principal
RIDGID R32104 Motor Bearings Replacement
Qué necesitas
  1. RIDGID R32104 Motor Bearings Replacement, Motor Brush: paso 1, imagen 1 de 2 RIDGID R32104 Motor Bearings Replacement, Motor Brush: paso 1, imagen 2 de 2
    • Turn off your saw and unplug before starting.
    • Place down the Worm Drive Saw on a sturdy surface.
    • The motor brush cap is located on the side of the main housing assembly, it can be identified as a large black plastic cap with a slit running down its surface.
  2. RIDGID R32104 Motor Bearings Replacement: paso 2, imagen 1 de 2 RIDGID R32104 Motor Bearings Replacement: paso 2, imagen 2 de 2
    • Using a flathead screwdriver, remove the motor brush cap from the main housing assembly.
  3. RIDGID R32104 Motor Bearings Replacement: paso 3, imagen 1 de 1
    • With the cap removed, the motor brush should now be accessible.
    • Carefully remove the motor brush by sliding it out of the main housing assembly.
  4. RIDGID R32104 Motor Bearings Replacement, Upper Blade Guard Assembly: paso 4, imagen 1 de 3 RIDGID R32104 Motor Bearings Replacement, Upper Blade Guard Assembly: paso 4, imagen 2 de 3 RIDGID R32104 Motor Bearings Replacement, Upper Blade Guard Assembly: paso 4, imagen 3 de 3
    • Maneuver the RIDGID saw, in order to easily remove the upper blade guard assembly.
    • Using the T20 Torx Screwdriver, remove the four 4/10 cm screws that attach to the gear box.
  5. RIDGID R32104 Motor Bearings Replacement: paso 5, imagen 1 de 2 RIDGID R32104 Motor Bearings Replacement: paso 5, imagen 2 de 2
    • Using the T50 Torx Screwdriver, remove the one 5/10 screw that attach to the gear box.
  6. RIDGID R32104 Motor Bearings Replacement: paso 6, imagen 1 de 2 RIDGID R32104 Motor Bearings Replacement: paso 6, imagen 2 de 2
    • Using the T20 Torx Screwdriver, remove the two 4/10 cm screws that attach to the handle of the device.
  7. RIDGID R32104 Motor Bearings Replacement: paso 7, imagen 1 de 2 RIDGID R32104 Motor Bearings Replacement: paso 7, imagen 2 de 2
    • Maneuver the saw to get to the base plate.
    • Using the T20 Torx Screwdriver, remove the two 4/10 cm screws that attach the upper blade guard’s base plate to the main housing assembly.
  8. RIDGID R32104 Motor Bearings Replacement, Main Housing Assembly: paso 8, imagen 1 de 2 RIDGID R32104 Motor Bearings Replacement, Main Housing Assembly: paso 8, imagen 2 de 2
    • Using the T20 Torx Screwdriver, remove the four 10 cm screws that attaches the main housing assembly to the gear box.
  9. RIDGID R32104 Motor Bearings Replacement, Gear Box: paso 9, imagen 1 de 2 RIDGID R32104 Motor Bearings Replacement, Gear Box: paso 9, imagen 2 de 2
    • Wiggle out the gear box to easily gain access to the motor rotor.
    • Once taken out, the motor rotor is easily accessible.
  10. RIDGID R32104 Motor Bearings Replacement, Motor Rotor: paso 10, imagen 1 de 3 RIDGID R32104 Motor Bearings Replacement, Motor Rotor: paso 10, imagen 2 de 3 RIDGID R32104 Motor Bearings Replacement, Motor Rotor: paso 10, imagen 3 de 3
    • The motor rotor is lodged in between the armature and can be identified as a rod containing a fan blade.
    • Carefully remove the motor rotor from the device.
  11. RIDGID R32104 Motor Bearings Replacement, Motor Bearings: paso 11, imagen 1 de 1
    • The bearings are located on the opposite end of the motor rotor, from where the fan blade was.
    • Carefully remove the motor bearings from the motor rotor.
Conclusión
2 personas más completaron esta guía.
Lucas Pimentel
Miembro Desde 04/02/19
1,010 Reputación
8 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 570
