Saltar al contenido principal
RIDGID R2740 Ball Bearing Replacement
Qué necesitas
  1. RIDGID R2740 Ball Bearing Replacement, Ball Bearing: paso 1, imagen 1 de 2 RIDGID R2740 Ball Bearing Replacement, Ball Bearing: paso 1, imagen 2 de 2
    • Orient the belt sander so that the AirGuard Technology logo is facing you.
    • Remove the nine 19mm, two 51mm and one 32 mm screws that hold the cover into place.
    • Remove the cover from the belt sander.
    • Make sure you remember the correct placement of each screw.
  2. RIDGID R2740 Ball Bearing Replacement: paso 2, imagen 1 de 1
    • Remove the assembly armature from the belt sander.
    • You may need to wiggle the assembly armature to remove it from the belt sander.
  3. RIDGID R2740 Ball Bearing Replacement: paso 3, imagen 1 de 2 RIDGID R2740 Ball Bearing Replacement: paso 3, imagen 2 de 2
    • Use a hammer to pry the ball bearing from the assembly armature.
    • The ball bearing can be somewhat difficult to remove. You may need to apply WD-40 before removal.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 20
Todo El Tiempo: 1,013
