Saltar al contenido principal
RIDGID Belt Sander R2740 Tension Lever Spring Replacement
Qué necesitas
  1. RIDGID Belt Sander R2740 Tension Lever Spring Replacement, Tension Lever Spring: paso 1, imagen 1 de 1
    • Turn the belt sander so that the RIDGID logo is facing you.
    • Flip the tension lever to the open position so that the tension on the spring is released.
    • Remove any sandpaper that is on the belt sander.
  2. RIDGID Belt Sander R2740 Tension Lever Spring Replacement: paso 2, imagen 1 de 3 RIDGID Belt Sander R2740 Tension Lever Spring Replacement: paso 2, imagen 2 de 3 RIDGID Belt Sander R2740 Tension Lever Spring Replacement: paso 2, imagen 3 de 3
    • Using the T20 Torx Screwdriver, remove the two (2) M4 X 19 mm screws on either side of the the belt tension release lever.
    • Remove the side plate to reveal the spring.
  3. RIDGID Belt Sander R2740 Tension Lever Spring Replacement: paso 3, imagen 1 de 2 RIDGID Belt Sander R2740 Tension Lever Spring Replacement: paso 3, imagen 2 de 2
    • Remove and replace the spring (OD 14.47mm X 38.1mm).
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 14
Ultimos 30 días: 30
Todo El Tiempo: 1,703
