Saltar al contenido principal
RIDGID Belt Sander R2740 Power Cord Replacement
Qué necesitas
  1. RIDGID Belt Sander R2740 Power Cord Replacement, Power Cord: paso 1, imagen 1 de 2 RIDGID Belt Sander R2740 Power Cord Replacement, Power Cord: paso 1, imagen 2 de 2
    • Orient the belt sander so that the RIDGID logo is facing you.
    • Remove the six 19 mm and three 51 mm T20 screws that hold the cover into place.
    • Remove the cover from the belt sander.
    • Make sure you remember the correct placement of each screw.
  2. RIDGID Belt Sander R2740 Power Cord Replacement: paso 2, imagen 1 de 2 RIDGID Belt Sander R2740 Power Cord Replacement: paso 2, imagen 2 de 2
    • Remove the two 16 mm T10 screws.
    • Remove the support bracket that holds the power cord into place.
  3. RIDGID Belt Sander R2740 Power Cord Replacement: paso 3, imagen 1 de 3 RIDGID Belt Sander R2740 Power Cord Replacement: paso 3, imagen 2 de 3 RIDGID Belt Sander R2740 Power Cord Replacement: paso 3, imagen 3 de 3
    • Lift the power cord from the resting grooves.
    • Rotate the switch so that the lock-on button is facing you.
    • Loosen the two 8 mm Phillips #3 screws.
    • Pull the two wires away from the switch.
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 5
Ultimos 30 días: 11
Todo El Tiempo: 646
