Saltar al contenido principal
RIDGID BELT SANDER R2740 Timing Belt Replacement
Qué necesitas
  1. RIDGID BELT SANDER R2740 Timing Belt Replacement, Timing Belt: paso 1, imagen 1 de 1
    • Orientate the sander so that the timing belt housing is facing you.
    • Remove the 19mm T20 screw from the center of the timing belt housing.
  2. RIDGID BELT SANDER R2740 Timing Belt Replacement: paso 2, imagen 1 de 1
    • Remove the timing belt housing.
  3. RIDGID BELT SANDER R2740 Timing Belt Replacement: paso 3, imagen 1 de 1
    • Use your finger or a screwdriver to apply pressure on the belt away from the sander near one of the small wheels.
    • Rotate the large wheel while applying pressure until the timing belt is free from the wheels.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 9
Ultimos 30 días: 27
Todo El Tiempo: 950
