Saltar al contenido principal
RCA Small Wonders Camcorder CC176 Viewfinder Replacement
Qué necesitas
  1. RCA Small Wonders Camcorder CC176 Viewfinder Replacement, Viewfinder: paso 1, imagen 1 de 3 RCA Small Wonders Camcorder CC176 Viewfinder Replacement, Viewfinder: paso 1, imagen 2 de 3 RCA Small Wonders Camcorder CC176 Viewfinder Replacement, Viewfinder: paso 1, imagen 3 de 3
    • Remove the 5 screws that secure the control panel (located on the top of the device) by using your small flathead screwdriver.
    • Loosen the panel from the device until you are able to remove it.
  2. RCA Small Wonders Camcorder CC176 Viewfinder Replacement: paso 2, imagen 1 de 3 RCA Small Wonders Camcorder CC176 Viewfinder Replacement: paso 2, imagen 2 de 3 RCA Small Wonders Camcorder CC176 Viewfinder Replacement: paso 2, imagen 3 de 3
    • Remove the remaining 21 screws on the camcorder.
    • Begin separating the plastic casing from the inner components of the device.
  3. RCA Small Wonders Camcorder CC176 Viewfinder Replacement: paso 3, imagen 1 de 2 RCA Small Wonders Camcorder CC176 Viewfinder Replacement: paso 3, imagen 2 de 2
    • Grasping the viewfinder in hand, carefully remove the two screws that secure the mounting device.
    • Locate the gray electrical cord that connects the viewfinder to the inner components of the camera. Gently unplug the gray cord and loosen the viewfinder from the device.
    • Separate the viewfinder from the device and feed the gray cord through the hole in the plastic casing.
Conclusión
Allison Baudoin
Miembro Desde 12/05/11
401 Reputación
4 Guías creadas
Equipo
James Madison, Team 2-1, Allen Fall 2011 Miembro de James Madison, Team 2-1, Allen Fall 2011
JMU-ALLEN-F11S2G1
2 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 1,272
