Saltar al contenido principal
RCA Small Wonders Camcorder CC176 Speaker Replacement
Qué necesitas
  1. RCA Small Wonders Camcorder CC176 Speaker Replacement, Speaker: paso 1, imagen 1 de 3 RCA Small Wonders Camcorder CC176 Speaker Replacement, Speaker: paso 1, imagen 2 de 3 RCA Small Wonders Camcorder CC176 Speaker Replacement, Speaker: paso 1, imagen 3 de 3
    • Remove the small black screws along the edges of the control panel on the top of the device.
    • Pry off the top control panel using the plastic wedge tool.
    • Remove the screw from the front, gray panel located beneath the "Scene Select AE" label.
    • Remove the two small black screws on the top of the front, gray panel of the device, above the red AUTOFOCUS letters.
  2. RCA Small Wonders Camcorder CC176 Speaker Replacement: paso 2, imagen 1 de 1
    • Turn the device over and remove the two screws securing the front panel of the device.
    • Remove the screw securing the primary viewfinder, along the front of the camera.
    • Using a flat plastic tool, pry the entire front panel away from the device.
  3. RCA Small Wonders Camcorder CC176 Speaker Replacement: paso 3, imagen 1 de 2 RCA Small Wonders Camcorder CC176 Speaker Replacement: paso 3, imagen 2 de 2
    • Gently unplug the grey cord, located underneath the panel, disconnecting the speaker from the inner component of the device.
    • Remove the speaker from the device.
Conclusión
Allison Baudoin
Miembro Desde 12/05/11
401 Reputación
4 Guías creadas
Equipo
James Madison, Team 2-1, Allen Fall 2011 Miembro de James Madison, Team 2-1, Allen Fall 2011
JMU-ALLEN-F11S2G1
2 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 12
Todo El Tiempo: 935
