Saltar al contenido principal
RCA RP3715A Motherboard Replacement
Qué necesitas
  1. RCA RP3715A Motherboard Replacement, Getting inside the device.: paso 1, imagen 1 de 1
    • Take out the six screws located on the back of the device.
    • The red screws are 10 mm Phillip's #1. The orange screws are 13 mm Phillips #1.
    • Three screws are located on the back panel. One is located inside the battery carriage.
    • Two screws are located on the on the back panel on the bottom left and right side.
  2. RCA RP3715A Motherboard Replacement, Relieve extension cord tension.: paso 2, imagen 1 de 3 RCA RP3715A Motherboard Replacement, Relieve extension cord tension.: paso 2, imagen 2 de 3 RCA RP3715A Motherboard Replacement, Relieve extension cord tension.: paso 2, imagen 3 de 3
    • Remove the 10 mm Phillip's #1 screw.
    • Then remove the metal reinforcement.
  3. RCA RP3715A Motherboard Replacement: paso 3, imagen 1 de 2 RCA RP3715A Motherboard Replacement: paso 3, imagen 2 de 2
    • Using flathead screwdriver undo the release tabs.
  4. RCA RP3715A Motherboard Replacement: paso 4, imagen 1 de 3 RCA RP3715A Motherboard Replacement: paso 4, imagen 2 de 3 RCA RP3715A Motherboard Replacement: paso 4, imagen 3 de 3
    • Pry the release tabs with a spudger.
    • Start with back of the device on the topside.
  5. RCA RP3715A Motherboard Replacement: paso 5, imagen 1 de 2 RCA RP3715A Motherboard Replacement: paso 5, imagen 2 de 2
    • Pry open both tabs to remove the topside of the clock.
  6. RCA RP3715A Motherboard Replacement, Speaker Replacement: paso 6, imagen 1 de 1
    • Remove the two 10mm Phillip's #1 screws. Also remove the two reinforcements holding the speaker in place.
  7. RCA RP3715A Motherboard Replacement, Detaching the front panel: paso 7, imagen 1 de 1
    • Remove the two 10 mm Phillip's #1 screws.
  8. RCA RP3715A Motherboard Replacement: paso 8, imagen 1 de 1
    • Remove the gray panel from the frame.
  9. RCA RP3715A Motherboard Replacement, Unlatch release tabs: paso 9, imagen 1 de 3 RCA RP3715A Motherboard Replacement, Unlatch release tabs: paso 9, imagen 2 de 3 RCA RP3715A Motherboard Replacement, Unlatch release tabs: paso 9, imagen 3 de 3
    • The two latches located in the picture will help take off the display.
    • Remove the display.
  10. RCA RP3715A Motherboard Replacement, Motherboard: paso 10, imagen 1 de 2 RCA RP3715A Motherboard Replacement, Motherboard: paso 10, imagen 2 de 2
    • asd
  11. RCA RP3715A Motherboard Replacement, Removing the top part of motherboard: paso 11, imagen 1 de 1
    • Remove the top 5 10mm Phillips #1 screws holding the top part of the motherboard
  12. RCA RP3715A Motherboard Replacement, Removing the side part of motherboard: paso 12, imagen 1 de 1
    • Remove the 5 10mm Phillip's #1 screws that holding side part of the motherboard
  13. RCA RP3715A Motherboard Replacement: paso 13, imagen 1 de 1
    • Remove the transformer by pulling back the release tab shown.
  14. RCA RP3715A Motherboard Replacement: paso 14, imagen 1 de 1
    • Pull the battery terminal through the whole shown.
  15. RCA RP3715A Motherboard Replacement, Lift the digital screen: paso 15, imagen 1 de 1
    • First release the latch highlighted in the picture. Then grab the screen by the bottom and lift it up.
  16. RCA RP3715A Motherboard Replacement, Lift the top piece of motherboard: paso 16, imagen 1 de 3 RCA RP3715A Motherboard Replacement, Lift the top piece of motherboard: paso 16, imagen 2 de 3 RCA RP3715A Motherboard Replacement, Lift the top piece of motherboard: paso 16, imagen 3 de 3
    • Remove the motherboard from the frame using the illustration shown.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team 10-5, Brown Fall 2014 Miembro de USF Tampa, Team 10-5, Brown Fall 2014
USFT-BROWN-F14S10G5
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 9
Todo El Tiempo: 551
