Saltar al contenido principal
RCA RP3715A Display Replacement
Qué necesitas
  1. RCA RP3715A Display Replacement, Reaching the battery terminal.: paso 1, imagen 1 de 2 RCA RP3715A Display Replacement, Reaching the battery terminal.: paso 1, imagen 2 de 2
    • Push down on the clip to release pressure. The pull off the plastic cover.
  2. RCA RP3715A Display Replacement, Replacing the battery: paso 2, imagen 1 de 1
    • Remove the 9-volt battery from the battery terminal.
  3. RCA RP3715A Display Replacement, Getting inside the device.: paso 3, imagen 1 de 1
    • Take out the six screws located on the back of the device.
    • The red screws are 10 mm Phillip's #1. The orange screws are 13 mm Phillips #1.
    • Three screws are located on the back panel. One is located inside the battery carriage.
    • Two screws are located on the on the back panel on the bottom left and right side.
  4. RCA RP3715A Display Replacement, Relieve extension cord tension.: paso 4, imagen 1 de 3 RCA RP3715A Display Replacement, Relieve extension cord tension.: paso 4, imagen 2 de 3 RCA RP3715A Display Replacement, Relieve extension cord tension.: paso 4, imagen 3 de 3
    • Remove the 10 mm Phillip's #1 screw.
    • Then remove the metal reinforcement.
  5. RCA RP3715A Display Replacement: paso 5, imagen 1 de 2 RCA RP3715A Display Replacement: paso 5, imagen 2 de 2
    • Using flathead screwdriver undo the release tabs.
  6. RCA RP3715A Display Replacement: paso 6, imagen 1 de 3 RCA RP3715A Display Replacement: paso 6, imagen 2 de 3 RCA RP3715A Display Replacement: paso 6, imagen 3 de 3
    • Pry the release tabs with a spudger.
    • Start with back of the device on the topside.
  7. RCA RP3715A Display Replacement: paso 7, imagen 1 de 2 RCA RP3715A Display Replacement: paso 7, imagen 2 de 2
    • Pry open both tabs to remove the topside of the clock.
  8. RCA RP3715A Display Replacement, Speaker Replacement: paso 8, imagen 1 de 1
    • Remove the two 10mm Phillip's #1 screws. Also remove the two reinforcements holding the speaker in place.
  9. RCA RP3715A Display Replacement, Detaching the front panel: paso 9, imagen 1 de 1
    • Remove the two 10 mm Phillip's #1 screws.
  10. RCA RP3715A Display Replacement: paso 10, imagen 1 de 1
    • Remove the gray panel from the frame.
  11. RCA RP3715A Display Replacement, Unlatch release tabs: paso 11, imagen 1 de 3 RCA RP3715A Display Replacement, Unlatch release tabs: paso 11, imagen 2 de 3 RCA RP3715A Display Replacement, Unlatch release tabs: paso 11, imagen 3 de 3
    • The two latches located in the picture will help take off the display.
    • Remove the display.
Conclusión
Una persona más ha completado esta guía.
Myles Waiters
Miembro Desde 09/22/14
370 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 10-5, Brown Fall 2014 Miembro de USF Tampa, Team 10-5, Brown Fall 2014
USFT-BROWN-F14S10G5
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 343
