Saltar al contenido principal
RCA RCT6773W22 Motherboard Replacement
Qué necesitas
  1. RCA RCT6773W22 Motherboard Replacement, Battery: paso 1, imagen 1 de 2 RCA RCT6773W22 Motherboard Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the two 5mm screws from the bottom of the device using a Phillips #000 screwdriver.
  2. RCA RCT6773W22 Motherboard Replacement: paso 2, imagen 1 de 3 RCA RCT6773W22 Motherboard Replacement: paso 2, imagen 2 de 3 RCA RCT6773W22 Motherboard Replacement: paso 2, imagen 3 de 3
    • Place the plastic opening tool between the case and the screen.
    • Slide the tool clockwise around the case until all the clips are removed.
    • Do not completely separate the case from the screen because there is a wire connecting the motherboard to the speaker.
  3. RCA RCT6773W22 Motherboard Replacement: paso 3, imagen 1 de 3 RCA RCT6773W22 Motherboard Replacement: paso 3, imagen 2 de 3 RCA RCT6773W22 Motherboard Replacement: paso 3, imagen 3 de 3
    • Desolder the two wires that connect the battery to the motherboard.
    • Learn more about soldering with this soldering technique guide.
    • Using the blue plastic opening tool, lift the battery away from the device.
  4. RCA RCT6773W22 Motherboard Replacement, Speaker: paso 4, imagen 1 de 3 RCA RCT6773W22 Motherboard Replacement, Speaker: paso 4, imagen 2 de 3 RCA RCT6773W22 Motherboard Replacement, Speaker: paso 4, imagen 3 de 3
    • Desolder the wire connected from the speaker to the motherboard.
    • Pry the speaker from the casing with a plastic opening tool.
  5. RCA RCT6773W22 Motherboard Replacement, Motherboard: paso 5, imagen 1 de 3 RCA RCT6773W22 Motherboard Replacement, Motherboard: paso 5, imagen 2 de 3 RCA RCT6773W22 Motherboard Replacement, Motherboard: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Use the spudger to lift up the black tab on all three ZIF connectors.
    • Use tweezers to remove the ribbon cables from the zift connectors.
  6. RCA RCT6773W22 Motherboard Replacement: paso 6, imagen 1 de 1
    • Use Phillips #000 screwdriver to remove the three 3mm screws on the motherboard.
  7. RCA RCT6773W22 Motherboard Replacement: paso 7, imagen 1 de 2 RCA RCT6773W22 Motherboard Replacement: paso 7, imagen 2 de 2
    • Use a spudger or plastic opening tool to lift up the motherboard.
Conclusión
6 personas más completaron esta guía.
Kelsea Weber
Miembro Desde 11/12/15
20,047 Reputación
32 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
140 Miembros
18,085 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 3,034
