Saltar al contenido principal
RCA RCT6773W22 Battery Replacement
Qué necesitas
  1. RCA RCT6773W22 Battery Replacement, Battery: paso 1, imagen 1 de 2 RCA RCT6773W22 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the two 5mm screws from the bottom of the device using a Phillips #000 screwdriver.
  2. RCA RCT6773W22 Battery Replacement: paso 2, imagen 1 de 3 RCA RCT6773W22 Battery Replacement: paso 2, imagen 2 de 3 RCA RCT6773W22 Battery Replacement: paso 2, imagen 3 de 3
    • Place the plastic opening tool between the case and the screen.
    • Slide the tool clockwise around the case until all the clips are removed.
    • Do not completely separate the case from the screen because there is a wire connecting the motherboard to the speaker.
  3. RCA RCT6773W22 Battery Replacement: paso 3, imagen 1 de 3 RCA RCT6773W22 Battery Replacement: paso 3, imagen 2 de 3 RCA RCT6773W22 Battery Replacement: paso 3, imagen 3 de 3
    • Desolder the two wires that connect the battery to the motherboard.
    • Learn more about soldering with this soldering technique guide.
    • Using the blue plastic opening tool, lift the battery away from the device.
Conclusión
2 personas más completaron esta guía.
Kelsea Weber
Miembro Desde 11/12/15
19,857 Reputación
32 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
135 Miembros
16,732 Guías creadas
Un comentario
Umm, which battery do you need for it? Seems that’s a part that is kind of important.
Cathy Hajo - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 10
Todo El Tiempo: 3,828
