Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Introducción
Upon using this guide, the user will be able to evaluate and repair problems occurring as a result of a stuck volume button. The guide outlines all tools and steps needed to perform the replacement.
  1. Remove the two 2.4mm x 4mm screws from the bottom of the tablet with a Phillips #00 Screwdriver.
    • Remove the two 2.4mm x 4mm screws from the bottom of the tablet with a Phillips #00 Screwdriver.
  2. Separate the front and back covers using one of the plastic opening tools.
    • Separate the front and back covers using one of the plastic opening tools.
  3. Dislodge the power button from the upper right corner of the tablet's back cover using the tweezers
    • Dislodge the power button from the upper right corner of the tablet's back cover using the tweezers
  4. Align and place the new replacement button with positive and negative engravings facing outward into the volume space found in the cover. Align and place the new replacement button with positive and negative engravings facing outward into the volume space found in the cover.
    • Align and place the new replacement button with positive and negative engravings facing outward into the volume space found in the cover.
Conclusión
Una persona más ha completado esta guía.
Kirby C
Miembro Desde 29/01/15
258 Reputación
1 Guía escrita
Equipo
Clemson, Team 14-4, Shirley Spring 2015 Miembro de Clemson, Team 14-4, Shirley Spring 2015
CLEM-SHIRLEY-S15S14G4
6 Miembros
15 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 140
