Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Introducción
If the screen of the device becomes cracked or stops registering touch commands, use the following guide to replace the screen.
  1. Remove two 2.4mm x 4mm screws from bottom of the tablet with Phillips #00 Screwdriver.
    • Remove two 2.4mm x 4mm screws from bottom of the tablet with Phillips #00 Screwdriver.
  2. Remove back cover with plastic opening tool, exposing the battery and motherboard. Remove back cover with plastic opening tool, exposing the battery and motherboard.
    • Remove back cover with plastic opening tool, exposing the battery and motherboard.
  3. Using the tweezers, remove the black tape connecting the screen to the motherboard. Using the tweezers, remove the black tape connecting the screen to the motherboard.
    • Using the tweezers, remove the black tape connecting the screen to the motherboard.
  4. Pull up the switch to remove the input connector. Pull up the switch to remove the input connector.
    • Pull up the switch to remove the input connector.
  5. Heat the iOpener in the microwave, following the instructions provided with the tool. Lay the heated iOpener on the front screen for two minutes to soften the connection of the screen to the tablet.
    • Heat the iOpener in the microwave, following the instructions provided with the tool. Lay the heated iOpener on the front screen for two minutes to soften the connection of the screen to the tablet.
  6. Use the suction cup and plastic opening tool to pry the front screen from the tablet. Use the suction cup and plastic opening tool to pry the front screen from the tablet.
    • Use the suction cup and plastic opening tool to pry the front screen from the tablet.
Conclusión
3 personas más completaron esta guía.
Matthew Wills
Miembro Desde 29/01/15
444 Reputación
4 Guías creadas
Equipo
Clemson, Team 14-4, Shirley Spring 2015 Miembro de Clemson, Team 14-4, Shirley Spring 2015
CLEM-SHIRLEY-S15S14G4
6 Miembros
15 Guías creadas
How to fix rca 7
Jagdeep Thandi - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 2,223
