Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y Herramientas
Introducción
If the power button is unresponsive, broken, or otherwise damaged, it may be time to replace the power button on your RCA tablet. This replacement guide will teach you how to properly open your device, remove the broken power button, and replace it with a new one.
  1. Remove two 2.4mm x 4mm screws from bottom of the tablet with Phillips #00 Screwdriver Remove two 2.4mm x 4mm screws from bottom of the tablet with Phillips #00 Screwdriver
    • Remove two 2.4mm x 4mm screws from bottom of the tablet with Phillips #00 Screwdriver
  2. Remove back cover with plastic opening tool, exposing the battery and motherboard. Remove back cover with plastic opening tool, exposing the battery and motherboard.
    • Remove back cover with plastic opening tool, exposing the battery and motherboard.
  3. Remove the power button from its slot with the tweezers. Remove the power button from its slot with the tweezers.
    • Remove the power button from its slot with the tweezers.
Conclusión
6 personas más completaron esta guía.
mikayla
Miembro Desde 29/01/15
390 Reputación
2 Guías creadas
Equipo
Clemson, Team 14-4, Shirley Spring 2015 Miembro de Clemson, Team 14-4, Shirley Spring 2015
CLEM-SHIRLEY-S15S14G4
6 Miembros
15 Guías creadas
You are the best!!
Thank You, Thank You, Thank You!!
Michael Stephenson - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 17
Todo El Tiempo: 2,977
