Introducción
After noticing your battery life deteriorate or you notice a bulge in the back of the device, it is time to replace the battery. In this guide, you will be removing the following parts:
- 1. Back Cover
- 2. Battery
Qué necesitas
Remove two 2.4mm x 4mm screws from bottom of the tablet with Phillips #00 Screwdriver.
The new wires must be soldered back into place on the motherboard at the original location.
For tips on soldering techniques, see this Soldering Guide
Una persona más ha completado esta guía.
