Saltar al contenido principal
RCA RCT6272W23 Speaker Replacement
Qué necesitas
  1. RCA RCT6272W23 Speaker Replacement, Case: paso 1, imagen 1 de 2 RCA RCT6272W23 Speaker Replacement, Case: paso 1, imagen 2 de 2
    • Use a Phillips #00 screwdriver to remove both 4.1 mm screws at the top of the device which hold it together.
  2. RCA RCT6272W23 Speaker Replacement: paso 2, imagen 1 de 2 RCA RCT6272W23 Speaker Replacement: paso 2, imagen 2 de 2
    • Press the plastic opening tool into the space between the front and back portions of the case.
    • Run it along the perimeter of the device to unhook the plastic tabs.
    • Gently pull both sides apart.
    • The speaker is connected to the back cover, so be careful when separating.
  3. RCA RCT6272W23 Speaker Replacement, Speaker: paso 3, imagen 1 de 1
    • Remove the soldered wire connections to the speaker.
    • Soldering irons can cause burns and severely damage your device. If in doubt, pause and think about it.
    • For more information about soldering, check out this guide.
  4. RCA RCT6272W23 Speaker Replacement: paso 4, imagen 1 de 1
    • Pry the speaker gently out of its plastic enclosure using a spudger.
Conclusión
Equipo
Michigan Tech, Team 1-5, Lauer Spring 2015 Miembro de Michigan Tech, Team 1-5, Lauer Spring 2015
MTU-LAUER-S15S1G5
2 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 3
Todo El Tiempo: 374
