Saltar al contenido principal
RCA RCT6272W23 Battery Replacement
Qué necesitas
  1. RCA RCT6272W23 Battery Replacement, Case: paso 1, imagen 1 de 2 RCA RCT6272W23 Battery Replacement, Case: paso 1, imagen 2 de 2
    • Use a Phillips #00 screwdriver to remove both 4.1 mm screws at the top of the device which hold it together.
  2. RCA RCT6272W23 Battery Replacement: paso 2, imagen 1 de 2 RCA RCT6272W23 Battery Replacement: paso 2, imagen 2 de 2
    • Press the plastic opening tool into the space between the front and back portions of the case.
    • Run it along the perimeter of the device to unhook the plastic tabs.
    • Gently pull both sides apart.
    • The speaker is connected to the back cover, so be careful when separating.
  3. RCA RCT6272W23 Battery Replacement, Battery: paso 3, imagen 1 de 1
    • Use a soldering iron to remove the soldered connections from the battery to the motherboard.
    • For your safety, and to ensure a correct repair, be sure to exercise caution when using the soldering iron.
    • For more information about soldering, check out this guide.
  4. RCA RCT6272W23 Battery Replacement: paso 4, imagen 1 de 1
    • Next, use the spudger to pry the battery off of the rest of the body.
    • The battery is taped on with double-sided tape. Prepare another strip of double-sided tape and have it ready to reattach the battery.
Conclusión
4 personas más completaron esta guía.
Equipo
Michigan Tech, Team 1-5, Lauer Spring 2015 Miembro de Michigan Tech, Team 1-5, Lauer Spring 2015
MTU-LAUER-S15S1G5
2 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 5,303
