Qué necesitas
Remove the two 2.5mm Phillips head screws before attempting to remove the screen from the device.
Remove the battery by first removing the electrical tape holding it down. Then begin gently prying underneath it and around the edges with your plastic opening tool, until the battery is loose.
Herramienta utilizada en este paso:Plastic Cards$2.99
To remove the LCD from the screen casing, gently pry it out of the clips that are holding it in place.
6 personas más completaron esta guía.
Un comentario
This was no help at all. What do you do after the final step? Where do I get a replacement LCD screen for this tablet?
I would really love to get a response soon, please. Thank you!
