Saltar al contenido principal
  1. Remove these two  2.5mm Phillip's head screws before attempting to remove the screen from the device. Remove these two  2.5mm Phillip's head screws before attempting to remove the screen from the device.
    • Remove these two 2.5mm Phillip's head screws before attempting to remove the screen from the device.
  2. Kits de Reparación de Android
    Estás a un kit de tu nueva pantalla o batería.
    Comprar Ahora
    Comprar Ahora
  3. Run an opening pick around the edge of the screen to loosen it and begin to pry upward. When the screen comes up like it has in the photo, it should be able to simply be removed from its casing.
    • Run an opening pick around the edge of the screen to loosen it and begin to pry upward.
    • When the screen comes up like it has in the photo, it should be able to simply be removed from its casing.
    • The buttons on the end of the device will be loose when you remove the screen from the backplate. Be careful not to lose them.
Conclusión
3 personas más completaron esta guía.
Ryan Williams
Miembro Desde 27/01/15
1,112 Reputación
4 Guías creadas
Equipo
Añadir comentario
Ver Estadísticas:
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
Global: 1,124
