Qué necesitas
Using a separating tool, look for a seam in the plastic casing that looks most accessible.
Use the prying tool to separate the front and back casing, working your way around the perimeter.
Utilize a card tool or a pick to assist in keeping the case separated.
Using a P00 Phillips screwdriver, remove the three screws securing the black plastic camera housing and remove it.
Peel back the beige tape while holding down the camera ribbon cable to prevent tears
Use a P00 Phillips screwdriver to remove the three screws securing the button board.
Desolder the contacts on the button board to remove or replace it.
Peel off the black tape on the battery and main-board.
Peel off the black tape securing the screen ribbon cable to the back of the screen.
Herramienta utilizada en este paso:Plastic Cards$2.99
Remove the yellow tape securing the battery to the screen.
Use a plastic card or pick to separate the battery from the screen.
Cut or desolder the wires on the battery to remove or replace it.
9 personas más completaron esta guía.
4 comentarios
Gracias y ademas la buenas fotografias ayudaron una inmesidad.
Kl
Nothing spectacular happened I just turned on my tablet today and voila! My display is crazed on part of the screen! I read these steps a couple times and I just don't understand how if this process is intended to replace the display screen a display screen isn't listed as a necessary part purchase. I have faith in reader generated sites so please help!
Denise a new display screen would need to be purchased. Unless you absolutely have to have this particular tablet fixed I suggest buying a new one.
hola, podrás tener este repuesto de la pantalla lcd para la venta para ese modelo?
gracias
William Weygel
williamw666@hotmail.com
