Saltar al contenido principal
RCA Pro10 Edition Camera Replacement
Qué necesitas
  1. RCA Pro10 Edition Camera Replacement, Speaker: paso 1, imagen 1 de 2 RCA Pro10 Edition Camera Replacement, Speaker: paso 1, imagen 2 de 2
    • Using a separating tool, look for a seam in the plastic casing that looks most accessible.
    • Use the prying tool to separate the front and back casing, working your way around the perimeter.
    • Utilize a card tool or a pick to assist in keeping the case separated.
    • To reassemble the device simply align the two casing halves and pinch to snap together or press down on the edges while the device in on a table.
  2. RCA Pro10 Edition Camera Replacement: paso 2, imagen 1 de 1
    • Flip over the back of the device while keeping it close to the front, the speaker is attached to it.
    • Remove the yellow tape securing the speaker to the back casing.
  3. RCA Pro10 Edition Camera Replacement: paso 3, imagen 1 de 2 RCA Pro10 Edition Camera Replacement: paso 3, imagen 2 de 2
    • Use the separating tool to pry the speaker from its surface.
    • Use caution when removing the speaker, you may damage the screen.
    • Cut or desolder the wires to replace or repair the speaker.
  4. RCA Pro10 Edition Camera Replacement, Camera: paso 4, imagen 1 de 3 RCA Pro10 Edition Camera Replacement, Camera: paso 4, imagen 2 de 3 RCA Pro10 Edition Camera Replacement, Camera: paso 4, imagen 3 de 3
    • Using a P00 Phillips screwdriver, remove the three screws securing the black plastic camera housing and remove it.
    • Peel back the beige tape while holding down the camera ribbon cable to prevent tears
  5. RCA Pro10 Edition Camera Replacement: paso 5, imagen 1 de 2 RCA Pro10 Edition Camera Replacement: paso 5, imagen 2 de 2
    • Lift the locking tab that is securing the camera ribbon cable.
    • Slide the ribbon cable out from the connector and remove from casing.
Conclusión
Dayne Russell
Miembro Desde 01/27/15
401 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 370
