Saltar al contenido principal
RCA Opal main board replacement
Qué necesitas
  1. RCA Opal main board replacement, Main Board: paso 1, imagen 1 de 3 RCA Opal main board replacement, Main Board: paso 1, imagen 2 de 3 RCA Opal main board replacement, Main Board: paso 1, imagen 3 de 3
    • For this procedure, you will need tweezers, a prying tool, and a Phillips J000 screwdriver.
  2. RCA Opal main board replacement: paso 2, imagen 1 de 2 RCA Opal main board replacement: paso 2, imagen 2 de 2
    • The RCA Opal should have a blue front cover and a black back cover.
  3. RCA Opal main board replacement: paso 3, imagen 1 de 2 RCA Opal main board replacement: paso 3, imagen 2 de 2
    • Place the blade of the tweezers in between the blue and black surfaces.
    • Twist and pull the blue plastic cover from the black back surface. You may need to work around the edges of the blue plastic in order to pry it free. It should come off in one piece.
  4. RCA Opal main board replacement: paso 4, imagen 1 de 1
    • The circular buttons should come off with the blue cover. If they do not, they can be removed with the prying tool.
  5. RCA Opal main board replacement: paso 5, imagen 1 de 3 RCA Opal main board replacement: paso 5, imagen 2 de 3 RCA Opal main board replacement: paso 5, imagen 3 de 3
    • Using the prying tool, insert the tip of the tool in between the black plastic and the back cover of the device.
    • Pull upward to pry the black plastic away from the device. It will come off in pieces, but this is okay.
    • There will be thin black plastic surrounding four clear pieces where the buttons used to be located. Remove this as well.
  6. RCA Opal main board replacement: paso 6, imagen 1 de 2 RCA Opal main board replacement: paso 6, imagen 2 de 2
    • Now you should be able to see the main board. A small gold connector strip will connect the screen to the main board.
    • Locate a small white rectangular connector found at the top middle of the main board.
    • Using a prying tool or your fingernail, move the black plastic piece located at the bottom of the white connector to an upward position (toward the screen).
    • This should free the gold connector strip and allow you to remove the screen.
  7. RCA Opal main board replacement: paso 7, imagen 1 de 1
    • Use the tweezers to pry off the black and silver plastic that lines the edges of the device.
  8. RCA Opal main board replacement: paso 8, imagen 1 de 3 RCA Opal main board replacement: paso 8, imagen 2 de 3 RCA Opal main board replacement: paso 8, imagen 3 de 3
    • Lift up to remove the black plastic outline that fits within the back cover. This will be connected to the main board and battery.
  9. RCA Opal main board replacement: paso 9, imagen 1 de 3 RCA Opal main board replacement: paso 9, imagen 2 de 3 RCA Opal main board replacement: paso 9, imagen 3 de 3
    • Locate four small screws on the four edges of the main board.
    • Using the Phillips +J000 screwdriver, remove these four screws.
    • This should disconnect the main board and battery from the remaining black plastic.
Conclusión
Jane Beaufore
Miembro Desde 09/24/15
219 Reputación
2 Guías creadas
Equipo
Ohio State, Team 1-1, Garvin Fall 2015 Miembro de Ohio State, Team 1-1, Garvin Fall 2015
OSU-GARVIN-F15S1G1
4 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 11
Todo El Tiempo: 704
