Saltar al contenido principal
RCA Maven Pro 11 Volume Button Replacement
Qué necesitas
  1. RCA Maven Pro 11 Volume Button Replacement, Cover: paso 1, imagen 1 de 2 RCA Maven Pro 11 Volume Button Replacement, Cover: paso 1, imagen 2 de 2
    • Remove all the 8 mm Phillips head screws on the side and back of the device.
  2. RCA Maven Pro 11 Volume Button Replacement: paso 2, imagen 1 de 2 RCA Maven Pro 11 Volume Button Replacement: paso 2, imagen 2 de 2
    • Pry off the cover by sticking a wedge in between the screen and the cover.
    • Be careful with the plastic because it can easily break.
    • Once the cover is partly removed, use your hands to take off the rest of the cover.
  3. RCA Maven Pro 11 Volume Button Replacement, Volume Button: paso 3, imagen 1 de 2 RCA Maven Pro 11 Volume Button Replacement, Volume Button: paso 3, imagen 2 de 2
    • Locate the volume button on the inside of the cover.
    • Slide a wedge between the cover and the volume button and lightly lift it off.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 124
