Saltar al contenido principal
RCA Maven Pro 11 Reset Button Replacement
Qué necesitas
  1. RCA Maven Pro 11 Reset Button Replacement, Cover: paso 1, imagen 1 de 2 RCA Maven Pro 11 Reset Button Replacement, Cover: paso 1, imagen 2 de 2
    • Remove all the 8 mm Phillips head screws on the side and back of the device.
  2. RCA Maven Pro 11 Reset Button Replacement: paso 2, imagen 1 de 2 RCA Maven Pro 11 Reset Button Replacement: paso 2, imagen 2 de 2
    • Pry off the cover by sticking a wedge in between the screen and the cover.
    • Be careful with the plastic because it can easily break.
    • Once the cover is partly removed, use your hands to take off the rest of the cover.
  3. RCA Maven Pro 11 Reset Button Replacement, Reset Button: paso 3, imagen 1 de 1
    • Locate the power button on the cover.
  4. RCA Maven Pro 11 Reset Button Replacement: paso 4, imagen 1 de 2 RCA Maven Pro 11 Reset Button Replacement: paso 4, imagen 2 de 2
    • Carefully pull up on the power button. There are two pins holding it in.
    • Remove the power button.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 14
Todo El Tiempo: 313
