Saltar al contenido principal
RCA Lyra X2400 USB port replacement
Qué necesitas
  1. RCA Lyra X2400 USB port replacement, Screen: paso 1, imagen 1 de 2 RCA Lyra X2400 USB port replacement, Screen: paso 1, imagen 2 de 2
    • Remove the two Phillips screws from the silver cover at the top of the Lyra.
    • Slowly wiggle the silver cover while pulling it away from the device.
  2. RCA Lyra X2400 USB port replacement: paso 2, imagen 1 de 2 RCA Lyra X2400 USB port replacement: paso 2, imagen 2 de 2
    • Remove the two Phillips screws from the bottom of the device, next to the charger port and Compact Flash release button.
    • Pull the silver case from the bottom of the device.
  3. RCA Lyra X2400 USB port replacement: paso 3, imagen 1 de 3 RCA Lyra X2400 USB port replacement: paso 3, imagen 2 de 3 RCA Lyra X2400 USB port replacement: paso 3, imagen 3 de 3
    • Carefully pry up the screen with a plastic opening tool.
    • Disconnect the screen's ribbon cable from the circuit board.
    • Remove the screen.
  4. RCA Lyra X2400 USB port replacement, Motherboard: paso 4, imagen 1 de 2 RCA Lyra X2400 USB port replacement, Motherboard: paso 4, imagen 2 de 2
    • Open the case of the Lyra.
    • Remove the four screws that secure the motherboard to the frame of the Lyra X2400.
  5. RCA Lyra X2400 USB port replacement, USB in/out: paso 5, imagen 1 de 2 RCA Lyra X2400 USB port replacement, USB in/out: paso 5, imagen 2 de 2
    • Locate the USB in/out component on your Lyra X2400. If you are having difficulty locating this component the picture to the left will show you where it is located.
    • Start using solder/desolder tools to remove the USB in/out.
    • Once removed replace it with the new working USB in/out.
    • Use the soldering tools to reattach the component back to the main logic board.
Conclusión
Joseph Goodwin
Miembro Desde 04/11/13
1 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 17-3, Regan Spring 2013 Miembro de Cal Poly, Team 17-3, Regan Spring 2013
CPSU-REGAN-S13S17G3
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 12
Todo El Tiempo: 222
