Saltar al contenido principal
RCA Lyra X2400 Audio Jack Replacement
Qué necesitas
  1. RCA Lyra X2400 Audio Jack Replacement, Screen: paso 1, imagen 1 de 2 RCA Lyra X2400 Audio Jack Replacement, Screen: paso 1, imagen 2 de 2
    • Remove the two Phillips screws from the silver cover at the top of the Lyra.
    • Slowly wiggle the silver cover while pulling it away from the device.
  2. RCA Lyra X2400 Audio Jack Replacement: paso 2, imagen 1 de 2 RCA Lyra X2400 Audio Jack Replacement: paso 2, imagen 2 de 2
    • Remove the two Phillips screws from the bottom of the device, next to the charger port and Compact Flash release button.
    • Pull the silver case from the bottom of the device.
  3. RCA Lyra X2400 Audio Jack Replacement: paso 3, imagen 1 de 3 RCA Lyra X2400 Audio Jack Replacement: paso 3, imagen 2 de 3 RCA Lyra X2400 Audio Jack Replacement: paso 3, imagen 3 de 3
    • Carefully pry up the screen with a plastic opening tool.
    • Disconnect the screen's ribbon cable from the circuit board.
    • Remove the screen.
  4. RCA Lyra X2400 Audio Jack Replacement, Motherboard: paso 4, imagen 1 de 2 RCA Lyra X2400 Audio Jack Replacement, Motherboard: paso 4, imagen 2 de 2
    • Open the case of the Lyra.
    • Remove the four screws that secure the motherboard to the frame of the Lyra X2400.
  5. RCA Lyra X2400 Audio Jack Replacement, Audio Jack: paso 5, imagen 1 de 2 RCA Lyra X2400 Audio Jack Replacement, Audio Jack: paso 5, imagen 2 de 2
    • Locate the audio jack on the Lyra X2400. If you have difficulty locating this component look at the picture to the left.
    • Start using the solder/desolder tools to remove this component.
    • Once removed replace the old audio jack with a new audio jack.
    • Use soldering tools to reattach this component back to the main logic board.
Conclusión
Joseph Goodwin
Miembro Desde 04/11/13
1 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 17-3, Regan Spring 2013 Miembro de Cal Poly, Team 17-3, Regan Spring 2013
CPSU-REGAN-S13S17G3
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 205
