Saltar al contenido principal
RCA CC310 Main Motherboard Replacement
Qué necesitas
  1. RCA CC310 Main Motherboard Replacement, Disassembling RCA CC310 Left Cover: paso 1, imagen 1 de 2 RCA CC310 Main Motherboard Replacement, Disassembling RCA CC310 Left Cover: paso 1, imagen 2 de 2
    • Remove the six 7.9mm Phillips #0 screws on the back and bottom.
    • Remove the one 3.8mm Phillips #0 screw on the bottom.
    • Remove the two 7.5mm Phillips #0 screws on the back and bottom.
  2. RCA CC310 Main Motherboard Replacement: paso 2, imagen 1 de 2 RCA CC310 Main Motherboard Replacement: paso 2, imagen 2 de 2
    • Remove 5.8mm Phillips #1 screw from the side button panel.
    • Slide the viewfinder all the way to the right and remove the 7.9mm Phillips #0 screw.
  3. RCA CC310 Main Motherboard Replacement: paso 3, imagen 1 de 2 RCA CC310 Main Motherboard Replacement: paso 3, imagen 2 de 2
    • Pry along the seam on the top side near the buttons with a spudger.
  4. RCA CC310 Main Motherboard Replacement: paso 4, imagen 1 de 2 RCA CC310 Main Motherboard Replacement: paso 4, imagen 2 de 2
    • Pull the left panel away from the rest of the camcorder.
    • Unplug the red speaker cable located at the rear of the device.
    • Be careful to not pull too hard. The speaker cable is still connected to the panel and it can rip.
  5. RCA CC310 Main Motherboard Replacement, Main Motherboard: paso 5, imagen 1 de 2 RCA CC310 Main Motherboard Replacement, Main Motherboard: paso 5, imagen 2 de 2
    • Pull back the plastic tabs along the edges of the motherboard.
    • Disconnect all the cables along the left side of the motherboard.
  6. RCA CC310 Main Motherboard Replacement: paso 6, imagen 1 de 2 RCA CC310 Main Motherboard Replacement: paso 6, imagen 2 de 2
    • Disconnect all cables along the bottom of the motherboard.
    • Pull the motherboard away from the camcorder.
  7. RCA CC310 Main Motherboard Replacement: paso 7, imagen 1 de 1
    • Desolder the two black wires holding the motherboard to the camcorder using a soldering iron.
Conclusión
Una persona más ha completado esta guía.
Oliver Adams
Miembro Desde 01/19/11
629 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 5-20, Amido Winter 2011 Miembro de Cal Poly, Team 5-20, Amido Winter 2011
CPSU-AMIDO-W11S5G20
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 2,696
