Saltar al contenido principal
RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement
Qué necesitas
  1. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Backplate: paso 1, imagen 1 de 3 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Backplate: paso 1, imagen 2 de 3 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Backplate: paso 1, imagen 3 de 3
    • Remove the three Phillips #00 screws at the bottom of the device.
  2. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: paso 2, imagen 1 de 2 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: paso 2, imagen 2 de 2
    • Remove the two Phillips #00 screws to the left and right of the keyboard connector.
  3. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: paso 3, imagen 1 de 1
    • Pull on one of the bottom corners to begin to pull off the back plate.
  4. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: paso 4, imagen 1 de 2 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: paso 4, imagen 2 de 2
    • Work around the outside of the chassis, using the spudger to pry the backplate off.
    • After doing this for about half the device, the backplate should pop right off.
  5. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Battery: paso 5, imagen 1 de 1
    • Remove the tape over the connectors on the motherboard and other side of the battery.
  6. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: paso 6, imagen 1 de 1
    • Disconnect the red and black keyboard wires connecting the battery to the motherboard.
  7. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: paso 7, imagen 1 de 1
    • Disconnect the black ribbon cable running over the battery. Flip up the black clamp and pull the cable out.
  8. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: paso 8, imagen 1 de 2 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: paso 8, imagen 2 de 2
    • Remove the cable over the battery connecting the motherboard and the power connector.
    • Flip up the black clamp and pull the cable out.
  9. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: paso 9, imagen 1 de 2 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: paso 9, imagen 2 de 2
    • Pull out battery. It is taped to the device so it is safe to pull out.
    • Look for damage to the battery. If damaged, make sure to not get any acid on your fingers.
  10. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Antenna: paso 10, imagen 1 de 1
    • Identify the grey wire on the right side of the device.
  11. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: paso 11, imagen 1 de 1
    • Remove the orange ribbon cable over the wire.
  12. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: paso 12, imagen 1 de 1
    • Remove the antenna using a soldering iron.
  13. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Motherboard: paso 13, imagen 1 de 1
    • Remove the blue and black wire from the top of the motherboard.
  14. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: paso 14, imagen 1 de 1
    • Remove the screws from the motherboard.
  15. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: paso 15, imagen 1 de 1
    • Remove the motherboard.
Conclusión
Marcus Elysee
Miembro Desde 10/25/19
97 Reputación
1 Guía escrita
Equipo
Un comentario
Where can I buy this motherboard?
waymond everett - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 1,370
