Saltar al contenido principal
RCA 10 Viking Pro RCT6K03W13 Battery Replacement
Qué necesitas
  1. RCA 10 Viking Pro RCT6K03W13 Battery Replacement, Backplate: paso 1, imagen 1 de 3 RCA 10 Viking Pro RCT6K03W13 Battery Replacement, Backplate: paso 1, imagen 2 de 3 RCA 10 Viking Pro RCT6K03W13 Battery Replacement, Backplate: paso 1, imagen 3 de 3
    • Remove the three Phillips #00 screws at the bottom of the device.
  2. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: paso 2, imagen 1 de 2 RCA 10 Viking Pro RCT6K03W13 Battery Replacement: paso 2, imagen 2 de 2
    • Remove the two Phillips #00 screws to the left and right of the keyboard connector.
  3. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: paso 3, imagen 1 de 1
    • Pull on one of the bottom corners to begin to pull off the back plate.
  4. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: paso 4, imagen 1 de 2 RCA 10 Viking Pro RCT6K03W13 Battery Replacement: paso 4, imagen 2 de 2
    • Work around the outside of the chassis, using the spudger to pry the backplate off.
    • After doing this for about half the device, the backplate should pop right off.
  5. RCA 10 Viking Pro RCT6K03W13 Battery Replacement, Battery: paso 5, imagen 1 de 1
    • Remove the tape over the connectors on the motherboard and other side of the battery.
  6. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: paso 6, imagen 1 de 1
    • Disconnect the red and black keyboard wires connecting the battery to the motherboard.
  7. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: paso 7, imagen 1 de 1
    • Disconnect the black ribbon cable running over the battery. Flip up the black clamp and pull the cable out.
  8. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: paso 8, imagen 1 de 2 RCA 10 Viking Pro RCT6K03W13 Battery Replacement: paso 8, imagen 2 de 2
    • Remove the cable over the battery connecting the motherboard and the power connector.
    • Flip up the black clamp and pull the cable out.
  9. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: paso 9, imagen 1 de 2 RCA 10 Viking Pro RCT6K03W13 Battery Replacement: paso 9, imagen 2 de 2
    • Pull out battery. It is taped to the device so it is safe to pull out.
    • Look for damage to the battery. If damaged, make sure to not get any acid on your fingers.
Conclusión
5 personas más completaron esta guía.
Ryan Wickett
Miembro Desde 10/25/19
632 Reputación
3 Guías creadas
Equipo
4 comentarios
Where can I get the battery for this?
Justin - Contestar
You can get a battery from Amazon or Walmart.com your wellcome ?
GLENDA Vandergrift -
How much voltage should the battery put out in order for the tablet to turn on?
Jesus Rios - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 30
Todo El Tiempo: 3,107
