Saltar al contenido principal
Herramientas
No se especificaron herramientas.
Partes
No se especificaron partes.
  1. Remove all wires then flip the laptop
    • Remove all wires then flip the laptop
  2. Remove the battery Remove the battery
    • Remove the battery
  3. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. Flip the Laptop, and unscrew the RAM cover. Flip the Laptop, and unscrew the RAM cover. Flip the Laptop, and unscrew the RAM cover.
    • Flip the Laptop, and unscrew the RAM cover.
  5. Unlock the RAM by pulling the locks outward. You'll know if its unlocked if it flips up in 45 degrees.
    • Unlock the RAM by pulling the locks outward.
    • You'll know if its unlocked if it flips up in 45 degrees.
  6. Pull the outer RAM. Repeat Step 4 and 5 for the other RAM. When returning, put the RAM back in at 45 degree angle, NOT 90 degree angle.
    • Pull the outer RAM. Repeat Step 4 and 5 for the other RAM.
    • When returning, put the RAM back in at 45 degree angle, NOT 90 degree angle.
Conclusión
trickster
Miembro Desde 23/12/13
1,941 Reputación
11 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 1
Todo El Tiempo: 855
