Saltar al contenido principal
RAM Replacement on Dell Latitude 5520 and 5530
Qué necesitas
  1. RAM Replacement on Dell Latitude 5520 and 5530, Introduction: paso 1, imagen 1 de 1
    • Take your RAM kit, an iFixit Mediator and a Phillips Screwdriver (if you have an iFixit Kit, you can go for the J1 bit on the Manta Toolkit ot the "1" on the Protech Toolkit)
  2. RAM Replacement on Dell Latitude 5520 and 5530, Removing the bottom Cover: paso 2, imagen 1 de 2 RAM Replacement on Dell Latitude 5520 and 5530, Removing the bottom Cover: paso 2, imagen 2 de 2
    • Unplug your computer from the charger, flip it on the back of the screen, remove the 9 captive screw (they will not fall from the bottom case) and use after the Mediator on all the side of the laptop to pop the bottom case off.
  3. RAM Replacement on Dell Latitude 5520 and 5530, Unplug the Battery: paso 3, imagen 1 de 3 RAM Replacement on Dell Latitude 5520 and 5530, Unplug the Battery: paso 3, imagen 2 de 3 RAM Replacement on Dell Latitude 5520 and 5530, Unplug the Battery: paso 3, imagen 3 de 3
    • Locate the Battery connector, it is mandatory to remove all power from the computer before working on the Hardware.
    • Unplug the battery by pulling on the black tab on the white connector. It doesn't require a lot of force.
  4. RAM Replacement on Dell Latitude 5520 and 5530, RAM Installation: paso 4, imagen 1 de 2 RAM Replacement on Dell Latitude 5520 and 5530, RAM Installation: paso 4, imagen 2 de 2
    • To remove the RAM, you will need to pull the metal bracket on both side of the RAM to free it and you can now remove it.
    • You can now plug the new sticks of RAM. To do it, you need to ensure that they are in their right spot.
    • If the RAM are in the right spot, when you will pull it down, you will hear both "clac" on both side of the RAM when the bracket are back on the right position.
  5. RAM Replacement on Dell Latitude 5520 and 5530, Put it back together: paso 5, imagen 1 de 1
    • You can now replug the battery and put back the bottom cover and the 9 screws
    • Don't forget to replug the battery!
  6. RAM Replacement on Dell Latitude 5520 and 5530, Tests and validation: paso 6, imagen 1 de 3 RAM Replacement on Dell Latitude 5520 and 5530, Tests and validation: paso 6, imagen 2 de 3 RAM Replacement on Dell Latitude 5520 and 5530, Tests and validation: paso 6, imagen 3 de 3
    • At the first restart (after 2 or 3 attempt), you will have and error message, saying that the amount memory have changed. You can either check it by the BIOS by clicking on "Go to BIOS" or clicking "Continue" to go to your operating System.
    • THe ultime validation is to check the amount of memory in your Operating system. If the correct amount is displayed, you're done!
Conclusión
And it's over :)
3 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
fr en
100%
¡ INFOREA nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
INFOREA
Miembro Desde 11/16/22
873 Reputación
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 19
Ultimos 7 días: 55
Ultimos 30 días: 155
Todo El Tiempo: 2,251
