Saltar al contenido principal
Quiksilver The Fifty50 Digital Battery Replacement
Qué necesitas
  1. Quiksilver The Fifty50 Digital Battery Replacement, Strap: paso 1, imagen 1 de 2 Quiksilver The Fifty50 Digital Battery Replacement, Strap: paso 1, imagen 2 de 2
    • Place the watch (face down) on a solid surface.
    • Carefully use the screwdriver and push in one side of the strap.
    • Slowly remove the strap by pushing back one of the hidden metallic holders for the strap.
    • If you are having difficulty trying to take off the strap, feel free to use a 3.5 flat head screw driver, or any kind of tool that make this step easier.
  2. Quiksilver The Fifty50 Digital Battery Replacement: paso 2, imagen 1 de 2 Quiksilver The Fifty50 Digital Battery Replacement: paso 2, imagen 2 de 2
    • Gently pull the pin out of the strap.
    • Carefully handle the small metallic holder, as they are sharp and may be difficult to locate if lost.
  3. Quiksilver The Fifty50 Digital Battery Replacement, Back Panel: paso 3, imagen 1 de 2 Quiksilver The Fifty50 Digital Battery Replacement, Back Panel: paso 3, imagen 2 de 2
    • Remove the four 1.1 mm screws holding the back panel in place using the Phillips #00 screwdriver.
  4. Quiksilver The Fifty50 Digital Battery Replacement: paso 4, imagen 1 de 1
    • Carefully separate the panel off of the watch.
    • Careful not to lose the four 1.1 mm screw or else the back panel will not be able to put back.
  5. Quiksilver The Fifty50 Digital Battery Replacement, Analog Battery: paso 5, imagen 1 de 2 Quiksilver The Fifty50 Digital Battery Replacement, Analog Battery: paso 5, imagen 2 de 2
    • Carefully lift the white plastic circular out of the watch.
  6. Quiksilver The Fifty50 Digital Battery Replacement: paso 6, imagen 1 de 3 Quiksilver The Fifty50 Digital Battery Replacement: paso 6, imagen 2 de 3 Quiksilver The Fifty50 Digital Battery Replacement: paso 6, imagen 3 de 3
    • Remove the four 1.1 mm screws located on the metallic holder using the Phillips #00 screwdriver.
  7. Quiksilver The Fifty50 Digital Battery Replacement: paso 7, imagen 1 de 3 Quiksilver The Fifty50 Digital Battery Replacement: paso 7, imagen 2 de 3 Quiksilver The Fifty50 Digital Battery Replacement: paso 7, imagen 3 de 3
    • Remove the large circular Analog battery.
  8. Quiksilver The Fifty50 Digital Battery Replacement, Circuit Board: paso 8, imagen 1 de 2 Quiksilver The Fifty50 Digital Battery Replacement, Circuit Board: paso 8, imagen 2 de 2
    • Using the Phillips #00 screwdriver, remove the two 1 mm screws holding the circuit board to the device.
  9. Quiksilver The Fifty50 Digital Battery Replacement: paso 9, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Remove the green circular chip using a pair of tweezers.
  10. Quiksilver The Fifty50 Digital Battery Replacement, Digital Battery: paso 10, imagen 1 de 2 Quiksilver The Fifty50 Digital Battery Replacement, Digital Battery: paso 10, imagen 2 de 2
    • Using the Phillips #00 screwdriver, remove the 1.1 mm screw that is holding the digital battery holder in place.
  11. Quiksilver The Fifty50 Digital Battery Replacement: paso 11, imagen 1 de 1
    • Use the magnetic pick-up tool to remove the small screw.
    • Careful to not lose this screw because it is crucial for putting the watch back.
  12. Quiksilver The Fifty50 Digital Battery Replacement: paso 12, imagen 1 de 1
    • Lift up the battery holder.
  13. Quiksilver The Fifty50 Digital Battery Replacement: paso 13, imagen 1 de 1
    • Remove the digital battery from the socket.
Conclusión
Sue Giske
Miembro Desde 07/16/19
622 Reputación
5 Guías creadas
Equipo
UW Tacoma, Team S1-G4, Liner Summer 2019 Miembro de UW Tacoma, Team S1-G4, Liner Summer 2019
UWT-LINER-SU19S1G4
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 25
Todo El Tiempo: 1,626
