Saltar al contenido principal
Quantum XTR05 Pinion Gear Replacement
  1. Quantum XTR05 Pinion Gear Replacement, Pinion Gear: paso 1, imagen 1 de 3 Quantum XTR05 Pinion Gear Replacement, Pinion Gear: paso 1, imagen 2 de 3 Quantum XTR05 Pinion Gear Replacement, Pinion Gear: paso 1, imagen 3 de 3
    • Unscrew by turning the cap counter-clockwise until it is separated from the spinning reel.
  2. Quantum XTR05 Pinion Gear Replacement: paso 2, imagen 1 de 3 Quantum XTR05 Pinion Gear Replacement: paso 2, imagen 2 de 3 Quantum XTR05 Pinion Gear Replacement: paso 2, imagen 3 de 3
    • Remove the spool line completely by pulling it away from the reel body.
  3. Quantum XTR05 Pinion Gear Replacement: paso 3, imagen 1 de 3 Quantum XTR05 Pinion Gear Replacement: paso 3, imagen 2 de 3 Quantum XTR05 Pinion Gear Replacement: paso 3, imagen 3 de 3
    • Remove the gear by pulling it up and off of the pinion.
    • Replace the pinion gear with your new one by aligning the shape of the gear opening and the pinion.
  4. Quantum XTR05 Pinion Gear Replacement: paso 4, imagen 1 de 2 Quantum XTR05 Pinion Gear Replacement: paso 4, imagen 2 de 2
    • Place the spool back onto the pinion.
    • Ensure that the spool is fitted properly.
  5. Quantum XTR05 Pinion Gear Replacement: paso 5, imagen 1 de 1
    • Place the spool release and drag adjustment piece back onto the top of the pinion.
  6. Quantum XTR05 Pinion Gear Replacement: paso 6, imagen 1 de 1
    • Screw the spool release and drag adjustment back into place in a clockwise direction until desired tension is achieved.
Linea de Meta
Nicholas Lynch
Miembro Desde 02/22/22
133 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 172
