Saltar al contenido principal
Quantum View 10.1 camera Replacement
Qué necesitas
  1. Quantum View 10.1 camera Replacement, Open Quantum View case: paso 1, imagen 1 de 1
    • Start by turning the tablet over with the screen down. Carefully use a plastic opening tool to pry the cover off. Start from the corner opposite the hibernate button.
  2. Quantum View 10.1 camera Replacement, Removing the electrical tape and magnets.: paso 2, imagen 1 de 2 Quantum View 10.1 camera Replacement, Removing the electrical tape and magnets.: paso 2, imagen 2 de 2
    • Pick up the magnets from the bottom edge of the tablet next to the keyboard connection and put them in a place that they will not get lost. Then carefully remove all 4 strips of electrical tape.
  3. Quantum View 10.1 camera Replacement, Unhooking the battery: paso 3, imagen 1 de 2 Quantum View 10.1 camera Replacement, Unhooking the battery: paso 3, imagen 2 de 2
    • Using a small plastic opening tool; genteelly pull the connection off of the motherboard.
    • Remove yellow plastic and carefully pull clip away from connection.
  4. Quantum View 10.1 camera Replacement, Remove camera clip: paso 5, imagen 1 de 2 Quantum View 10.1 camera Replacement, Remove camera clip: paso 5, imagen 2 de 2
    • Remove yellow tape.
    • Unclip ribbon connector.
  5. Quantum View 10.1 camera Replacement, Remove camera: paso 6, imagen 1 de 2 Quantum View 10.1 camera Replacement, Remove camera: paso 6, imagen 2 de 2
    • Unscrew plastic camera holder using a PH00 screwdriver bit.
    • Release the plastic holder tab and remove camera.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 10
Todo El Tiempo: 155
