Saltar al contenido principal
Quantum View 10.1 Battery Replacement
Qué necesitas
  1. Quantum View 10.1 Battery Replacement, Open Quantum View case: paso 1, imagen 1 de 1
    • Start by turning the tablet over with the screen down. Carefully use a plastic opening tool to pry the cover off. Start from the corner opposite the hibernate button.
  2. Quantum View 10.1 Battery Replacement, Removing the electrical tape and magnets.: paso 2, imagen 1 de 2 Quantum View 10.1 Battery Replacement, Removing the electrical tape and magnets.: paso 2, imagen 2 de 2
    • Pick up the magnets from the bottom edge of the tablet next to the keyboard connection and put them in a place that they will not get lost. Then carefully remove all 4 strips of electrical tape.
  3. Quantum View 10.1 Battery Replacement, Unhooking the battery: paso 3, imagen 1 de 2 Quantum View 10.1 Battery Replacement, Unhooking the battery: paso 3, imagen 2 de 2
    • Using a small plastic opening tool; genteelly pull the connection off of the motherboard.
Conclusión
3 comentarios
How do I find a replacement battery?
Chris Clayton - Contestar
Seems finding the right battery is a problem
where can I find a replacement battery and screen for this i only have the motherboard lying around and i really want to repair it so i can access old data
aabel joby - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 887
