Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Qualcomm Snapdragon 800 Mobile Development Speakers Replacement
Qué necesitas
  1. Qualcomm Snapdragon 800 Mobile Development Speakers Replacement, Battery: paso 1, imagen 1 de 2 Qualcomm Snapdragon 800 Mobile Development Speakers Replacement, Battery: paso 1, imagen 2 de 2
    • Locate your device.
    • Flip device onto its back.
  2. Qualcomm Snapdragon 800 Mobile Development Speakers Replacement: paso 2, imagen 1 de 1
    • Remove the tablet's back cover.
  3. Qualcomm Snapdragon 800 Mobile Development Speakers Replacement: paso 3, imagen 1 de 1
    • Locate the battery and remove it.
    • If you wish to replace the battery you can do so here.
  4. Qualcomm Snapdragon 800 Mobile Development Speakers Replacement, Back Panel: paso 4, imagen 1 de 2 Qualcomm Snapdragon 800 Mobile Development Speakers Replacement, Back Panel: paso 4, imagen 2 de 2
    • Use the Phillips PH1 screwdriver to unscrew the five 4x2.5mm screws that hold the back cover.
  5. Qualcomm Snapdragon 800 Mobile Development Speakers Replacement: paso 5, imagen 1 de 1
    • Pop out the back cover.
  6. Qualcomm Snapdragon 800 Mobile Development Speakers Replacement, Motherboard: paso 6, imagen 1 de 3 Qualcomm Snapdragon 800 Mobile Development Speakers Replacement, Motherboard: paso 6, imagen 2 de 3 Qualcomm Snapdragon 800 Mobile Development Speakers Replacement, Motherboard: paso 6, imagen 3 de 3
    • Start by disconnecting the cables attached to the motherboard
    • use the spudger to lift the connectors vertically off. They should pop off with relative ease
    • The last connector has a yellow tab. Pull up on the tab until the small metal catch lifts up. Then pull straight back to remove the connector from its socket.
  7. Qualcomm Snapdragon 800 Mobile Development Speakers Replacement: paso 7, imagen 1 de 1
    • Using the Phillips PH1, remove all 6 of the 3x2.5mm screws (circled in red) holding the motherboard in place.
  8. Qualcomm Snapdragon 800 Mobile Development Speakers Replacement: paso 8, imagen 1 de 1
    • Using the spudger lift the motherboard out of the tablet frame.
  9. Qualcomm Snapdragon 800 Mobile Development Speakers Replacement, Speakers: paso 9, imagen 1 de 1
    • Locate the two speakers in each of the bottom corners (left and right).
  10. Qualcomm Snapdragon 800 Mobile Development Speakers Replacement: paso 10, imagen 1 de 1
    • Use the Phillips PH1 screwdriver to remove the 3x2.5mm screw on the right speaker.
  11. Qualcomm Snapdragon 800 Mobile Development Speakers Replacement: paso 11, imagen 1 de 1
    • Use the spudger to disconnect the speakers.
  12. Qualcomm Snapdragon 800 Mobile Development Speakers Replacement: paso 12, imagen 1 de 1
    • Lift the speakers out.
Conclusión
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 36
Todo El Tiempo: 494
