Saltar al contenido principal
Qualcomm QCP-2760 Keypad Replacement
Qué necesitas
  1. Qualcomm QCP-2760 Keypad Replacement, Battery: paso 1, imagen 1 de 1
    • Unscrew the back battery plate from the phone using a T6 Torx screwdriver.
    • The screw does not need to be removed completely, the back battery plate will unhinge from the phone.
  2. Qualcomm QCP-2760 Keypad Replacement, Rear Backing: paso 2, imagen 1 de 2 Qualcomm QCP-2760 Keypad Replacement, Rear Backing: paso 2, imagen 2 de 2
    • Using the T6 Torx screwdriver, remove the two screws located at the bottom of the back of the phone.
    • Find the seam between the front and back of the phone
    • Pry the seam open using a plastic opening tool, or your fingers.
    • Some force is required
  3. Qualcomm QCP-2760 Keypad Replacement, Motherboard: paso 3, imagen 1 de 1
    • Locate the four metal clips holding the motherboard onto the phone.
    • Pull the clips away from the motherboard while lifting the motherboard out of the case.
    • The motherboard is attached to the case by a fragile cable, do not apply any stress to the cable.
  4. Qualcomm QCP-2760 Keypad Replacement: paso 4, imagen 1 de 2 Qualcomm QCP-2760 Keypad Replacement: paso 4, imagen 2 de 2
    • Place the motherboard down so that the screen is facing up.
    • Grab the small brown connector plug at the sides with a fingernail or tweezers and flip it up.
    • Locate, but do not disconnect, the four screen clips.
  5. Qualcomm QCP-2760 Keypad Replacement: paso 5, imagen 1 de 2 Qualcomm QCP-2760 Keypad Replacement: paso 5, imagen 2 de 2
    • Flip the motherboard over so that the screen is facing down.
    • Again, be careful not to put stress on the speaker cable.
  6. Qualcomm QCP-2760 Keypad Replacement, Keypad: paso 6, imagen 1 de 1
    • Remove keypad circuit board by lifting up circuit board while pulling clip.
    • Remove rubber keypad
    • Insert new rubber keypad.
Conclusión
Colin Packard
Miembro Desde 09/30/14
101 Reputación
1 Guía escrita
Equipo
Ohio State, Team 1-4, Buehl Fall 2014 Miembro de Ohio State, Team 1-4, Buehl Fall 2014
OSU-BUEHL-F14S1G4
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 11
Todo El Tiempo: 191
