Saltar al contenido principal
Qanba Crystal Joystick and Buttons Replacement
Qué necesitas
  1. Qanba Crystal Joystick and Buttons Replacement, Button, Joystick and Artwork: paso 1, imagen 1 de 3 Qanba Crystal Joystick and Buttons Replacement, Button, Joystick and Artwork: paso 1, imagen 2 de 3 Qanba Crystal Joystick and Buttons Replacement, Button, Joystick and Artwork: paso 1, imagen 3 de 3
    • Use the Phillips #1 screwdriver to remove the eight 20 mm screws.
    • Remove the metal plate to gain access to the internals of the device.
  2. Qanba Crystal Joystick and Buttons Replacement: paso 2, imagen 1 de 3 Qanba Crystal Joystick and Buttons Replacement: paso 2, imagen 2 de 3 Qanba Crystal Joystick and Buttons Replacement: paso 2, imagen 3 de 3
    • Taking a picture or marking cables with masking tape is advised as it will help with the reassembly process.
    • Each button has three cables, unplug these from each one.
    • The joystick has two cables, unplug both of these.
    • The use of ESD safe tweezers may assist with unplugging the cables.
  3. Qanba Crystal Joystick and Buttons Replacement: paso 3, imagen 1 de 3 Qanba Crystal Joystick and Buttons Replacement: paso 3, imagen 2 de 3 Qanba Crystal Joystick and Buttons Replacement: paso 3, imagen 3 de 3
    • Use the Phillips #1 screwdriver to remove the four 10 mm screws.
    • Use a flathead screwdriver to hold the screw in place.
    • Twist off the ball top of the joystick while holding the screw in place with a screwdriver.
    • Remove the joystick and all of it's components.
  4. Qanba Crystal Joystick and Buttons Replacement: paso 4, imagen 1 de 1
    • Press in the tabs on the top and bottom of the buttons to remove them.
    • The outline of the buttons are sharp, do exercise caution with the removal of the buttons.
  5. Qanba Crystal Joystick and Buttons Replacement: paso 5, imagen 1 de 3 Qanba Crystal Joystick and Buttons Replacement: paso 5, imagen 2 de 3 Qanba Crystal Joystick and Buttons Replacement: paso 5, imagen 3 de 3
    • Flip the controller over.
    • Peel the six shiny stickers and their epoxy glue off of the controller.
    • Remove the six newly revealed Phillips screws.
    • Remove the acrylic panel.
Conclusión
Kevin Vu
Miembro Desde 06/29/21
121 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 29
Ultimos 30 días: 98
Todo El Tiempo: 1,992
