Saltar al contenido principal
Pyle Astro PTBL7C LCD Replacement
Qué necesitas
  1. Pyle Astro PTBL7C LCD Replacement, LCD: paso 1, imagen 1 de 2 Pyle Astro PTBL7C LCD Replacement, LCD: paso 1, imagen 2 de 2
    • Using the plastic opening tool, work your way along the edge of the tablet.
    • The display is held in place by plastic tabs which slide into recesses in the rear plastic panel.
    • Once all clips are released, gently open and separate the front display assembly and the rear plastic panel.
    • Place the front display assembly facing front side down to expose the inside.
  2. Pyle Astro PTBL7C LCD Replacement: paso 2, imagen 1 de 2 Pyle Astro PTBL7C LCD Replacement: paso 2, imagen 2 de 2
    • Remove the three 4 mm JIS #0 screws to release the PCB board.
  3. Pyle Astro PTBL7C LCD Replacement: paso 3, imagen 1 de 1
    • The display is held in place by plastic tabs which slide over the outer edges of the backside of the display.
    • Gently work your way around the display while pulling the plastic tabs back to release the LCD display from the front panel.
  4. Pyle Astro PTBL7C LCD Replacement: paso 4, imagen 1 de 1
    • Once all clips are released gently open and separate the front plastic display from the LCD and place the LCD face down.
    • The front plastic display contains the external touch panel, and the capacitive touch screen overlay.
  5. Pyle Astro PTBL7C LCD Replacement: paso 5, imagen 1 de 1
    • Using both hands, gently release the ribbon cable to the capacitive touch screen overlay from the PCB board by pushing both gray tabs outwards.
  6. Pyle Astro PTBL7C LCD Replacement: paso 6, imagen 1 de 1
  7. Pyle Astro PTBL7C LCD Replacement: paso 7, imagen 1 de 1
    Herramienta utilizada en este paso:
    Plastic Cards
    $2.99
    Comprar
    • Using a plastic card, gently remove the adhesive that holds the battery in place and separate the battery from the LCD panel.
    • Exercise extreme caution and be sure to not rupture the battery casing.
  8. Pyle Astro PTBL7C LCD Replacement: paso 8, imagen 1 de 1
Conclusión
Andrew Redifer
Miembro Desde 03/27/18
265 Reputación
2 Guías creadas
Equipo
IUPUI, Team S3-G6, Harley Spring 2018 Miembro de IUPUI, Team S3-G6, Harley Spring 2018
IUPUI-HARLEY-S18S3G6
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 11
Todo El Tiempo: 286
