Saltar al contenido principal
Purple SmartVP Mount Replacement
Qué necesitas
  1. Purple SmartVP Mount Replacement, Mount: paso 1, imagen 1 de 3 Purple SmartVP Mount Replacement, Mount: paso 1, imagen 2 de 3 Purple SmartVP Mount Replacement, Mount: paso 1, imagen 3 de 3
    • Remove the top bar by removing the 5cm hex T10 screws on the back of the device as shown. Then gently pull off the top bar from the main component.
  2. Purple SmartVP Mount Replacement: paso 2, imagen 1 de 2 Purple SmartVP Mount Replacement: paso 2, imagen 2 de 2
    • Locate and release the flap on the side of your device's mount. This will allow you to slide the adjustable portion of the mount.
  3. Purple SmartVP Mount Replacement: paso 3, imagen 1 de 2 Purple SmartVP Mount Replacement: paso 3, imagen 2 de 2
    • Using a #4.0 flathead screwdriver, unscrew your mount from the bottom and remove the 1.2cm screw.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 128
