Saltar al contenido principal
Puritan Bennett 840 Oxygen Sensor Replacement
Equipo médico
El fabricante de este equipo médico no ha avalado o contratado a iFixit ni a esta guía de reparación.
  1. Puritan Bennett 840 Oxygen Sensor Replacement, Oxygen Sensor: paso 1, imagen 1 de 1
    • Locate the flexible oxygen sensor access cover on the top edge of the cabinet and firmly push the center of the lower flap of the access cover until the lower flap is dislodged from the cabinet.
  2. Puritan Bennett 840 Oxygen Sensor Replacement: paso 2, imagen 1 de 1
    • Pinch the bottom and top flaps of the access cover firmly together and pull the access cover away from the cabinet to remove.
  3. Puritan Bennett 840 Oxygen Sensor Replacement: paso 3, imagen 1 de 1
    • Press the small white release tab away from the sensor cable connector to release the sensor cable connector.
    • While continually pressing the release tab, gently pull the connector from the oxygen sensor.
  4. Puritan Bennett 840 Oxygen Sensor Replacement: paso 4, imagen 1 de 1
    • Unscrew (counter-clockwise) and remove the oxygen sensor.
  5. Puritan Bennett 840 Oxygen Sensor Replacement: paso 5, imagen 1 de 1
    • Open the replacement oxygen sensor and O-ring. Make sure the O-ring is at the threaded base of the oxygen sensor, and screw (clockwise) until snug.
Conclusión
To reassemble your device, follow these instructions in reverse order. Calibrate new oxygen sensor by pressing 100% O2/ CAL 2 min key. Run an SST to check the system before using the ventilator on a patient.
2 personas más completaron esta guía.
Gabrielle Reyes
Miembro Desde 04/09/20
154 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S7-G4, Paton Spring 2020 Miembro de Cal Poly, Team S7-G4, Paton Spring 2020
CPSU-PATON-S20S7G4
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 24
Todo El Tiempo: 1,573
