Saltar al contenido principal
Puritan Bennett 560 Internal Battery Replacement
Equipo médico
El fabricante de este equipo médico no ha avalado o contratado a iFixit ni a esta guía de reparación.
Qué necesitas
  1. Puritan Bennett 560 Internal Battery Replacement, Internal Battery: paso 1, imagen 1 de 1
    • REMOVAL
    • Locate the battery cover on the rear of the ventilator.
  2. Puritan Bennett 560 Internal Battery Replacement: paso 2, imagen 1 de 1
    • Using the T10 Torx screwdriver, remove the three 8mm screws on the battery cover.
    • Two screws are located on the rear of the ventilator, and one on the bottom.
    • Slide the battery cover out of the ventilator.
    • Remove the battery from the battery cover.
  3. Puritan Bennett 560 Internal Battery Replacement: paso 3, imagen 1 de 1
    • REPLACEMENT
    • Install the battery into cover, as shown in figure.
    • Make sure the contacts on the battery line up with those in the ventilator.
    • Slide the battery and cover together into the housing.
    • While applying pressure to the cover, install the two rear screws.
    • Install the screw at the bottom of the cover.
    • Be careful not to over-tighten any screws.
Linea de Meta
2 personas más completaron esta guía.
Theo Philliber
Miembro Desde 04/07/20
201 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S11-G20, Paton Spring 2020 Miembro de Cal Poly, Team S11-G20, Paton Spring 2020
CPSU-PATON-S20S11G20
2 Miembros
3 Guías creadas
Un comentario
I can’t seem to edit the step titles. They should show:
Step 1: Battery Removal
Step 2:
Step 3: Battery Replacement
Theo Philliber - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 502
