Saltar al contenido principal
Puritan Bennett 540 Alarm Resetting Technique
Equipo médico
El fabricante de este equipo médico no ha avalado o contratado a iFixit ni a esta guía de reparación.
  1. Puritan Bennett 540 Alarm Resetting Technique, Puritan Bennett 540 Alarm Resetting Technique: paso 1, imagen 1 de 1
    • Press the MENU Key to access the Alarm Settings Menu.
  2. Puritan Bennett 540 Alarm Resetting Technique: paso 2, imagen 1 de 2 Puritan Bennett 540 Alarm Resetting Technique: paso 2, imagen 2 de 2
    • Press the down arrow key to position the cursor on the “Alarm Logs” line, if this is not already the case.
  3. Puritan Bennett 540 Alarm Resetting Technique: paso 3, imagen 1 de 1
    • Press the Enter key to confirm the selection of the Alarm Menu.
  4. Puritan Bennett 540 Alarm Resetting Technique: paso 4, imagen 1 de 2 Puritan Bennett 540 Alarm Resetting Technique: paso 4, imagen 2 de 2
    • Press the up arrow key to position the cursor on the “Reactivate Paused Alarm” line. The following graphic shows the resulting display.
  5. Puritan Bennett 540 Alarm Resetting Technique: paso 5, imagen 1 de 3 Puritan Bennett 540 Alarm Resetting Technique: paso 5, imagen 2 de 3 Puritan Bennett 540 Alarm Resetting Technique: paso 5, imagen 3 de 3
    • Press the Enter key for at least three (3) seconds. The following events occur:
    • A “beep” sounds.
    • An audible alarm sounds.
    • An alarm indicator illuminates.
    • The messages of all active alarms are displayed in a loop in the Ventilation and Alarm menus.
    • The Audio Paused symbol disappears (if it was displayed).
    • The Alarm Paused symbol disappears.
Conclusión
There is no need to reassemble the device, but if the condition persists you can try resetting the audio again.
kerribyrne
Miembro Desde 04/08/20
267 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S7-G7, Paton Spring 2020 Miembro de Cal Poly, Team S7-G7, Paton Spring 2020
CPSU-PATON-S20S7G7
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 6
Todo El Tiempo: 113
