Saltar al contenido principal
Puritan Bennett 540 Air Inlet Filter Replacement
Equipo médico
El fabricante de este equipo médico no ha avalado o contratado a iFixit ni a esta guía de reparación.
Qué necesitas
  1. Puritan Bennett 540  Air Inlet Filter Replacement, Air Inlet Filter: paso 1, imagen 1 de 1
    • Hold the filter between your fingers and pinch. Pull the filter outwards (towards you).
  2. Puritan Bennett 540  Air Inlet Filter Replacement: paso 2, imagen 1 de 1
    • Remove the filter and discard it. Do not save it. When removed, it should look like the attached image.
    • Place the new filter in the device by making sure that:
    • a. The fine particle side of the filter faces outwards, away from the ventilator.
    • b. The filter is properly installed in its housing. Proper installation of the filter prevents particles from entering the device. Remember that the air inlet filter is not reusable; do not wash, clean, or reuse it!
Conclusión
There is no reassembly needed after replacing the inlet filter.
kerribyrne
Miembro Desde 04/08/20
267 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S7-G7, Paton Spring 2020 Miembro de Cal Poly, Team S7-G7, Paton Spring 2020
CPSU-PATON-S20S7G7
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 82
