Saltar al contenido principal
Prusa i3 MK3 Filament Sensor Replacement
Qué necesitas
  1. Prusa i3 MK3 Filament Sensor Replacement, Filament Sensor: paso 1, imagen 1 de 3 Prusa i3 MK3 Filament Sensor Replacement, Filament Sensor: paso 1, imagen 2 de 3 Prusa i3 MK3 Filament Sensor Replacement, Filament Sensor: paso 1, imagen 3 de 3
    • Orient the printer so that the screen is facing to the left.
    • Using the On/Off button, switch the printer into the Off position.
    • Ensure your printer is off by visually inspecting the screen. If the screen is not lit up, your printer is off.
    • Ensure the printer has cooled to room temperature before beginning disassembly.
  2. Prusa i3 MK3 Filament Sensor Replacement: paso 2, imagen 1 de 3 Prusa i3 MK3 Filament Sensor Replacement: paso 2, imagen 2 de 3 Prusa i3 MK3 Filament Sensor Replacement: paso 2, imagen 3 de 3
    • Orient the printer so that the top of the extruder head can be accessed.
    • Remove the two 2.5mm X 10mm socket head screws. These screws secure the cover of the filament sensor.
    • Remove the filament sensor cover.
  3. Prusa i3 MK3 Filament Sensor Replacement: paso 3, imagen 1 de 2 Prusa i3 MK3 Filament Sensor Replacement: paso 3, imagen 2 de 2
    • Orient the printer so that the screen is facing to the right.
    • Loosen the two 2.5mm X 40mm socket head screws while holding the extruder head firmly, keeping pressure on the opposite side.
    • Ensure the screws have cleared the embedded square nuts on the back side.
    • Be careful not to lose the small springs that are held in place by the screws.
  4. Prusa i3 MK3 Filament Sensor Replacement: paso 4, imagen 1 de 2 Prusa i3 MK3 Filament Sensor Replacement: paso 4, imagen 2 de 2
    • Remove the 3D-printed cover piece on top of the extruder access door. (Your printer might be missing this part.)
  5. Prusa i3 MK3 Filament Sensor Replacement: paso 5, imagen 1 de 3 Prusa i3 MK3 Filament Sensor Replacement: paso 5, imagen 2 de 3 Prusa i3 MK3 Filament Sensor Replacement: paso 5, imagen 3 de 3
    • Orient the printer so that the screen is facing away from you.
    • Remove the 2.5mm X 30mm socket head screw located on the top left of the backside of the extruder head.
    • Rotate the printer so that the screen is facing to the left.
    • Remove the extruder access door from the extruder head.
    • Be careful not to lose the square nuts that hold the screws removed in Step 3. (They sit inside the extruder access door.)
  6. Prusa i3 MK3 Filament Sensor Replacement: paso 6, imagen 1 de 3 Prusa i3 MK3 Filament Sensor Replacement: paso 6, imagen 2 de 3 Prusa i3 MK3 Filament Sensor Replacement: paso 6, imagen 3 de 3
    • Remove the 2.5mm X 10mm socket head screw located behind the extruder access door that was removed in Step 5.
  7. Prusa i3 MK3 Filament Sensor Replacement: paso 7, imagen 1 de 3 Prusa i3 MK3 Filament Sensor Replacement: paso 7, imagen 2 de 3 Prusa i3 MK3 Filament Sensor Replacement: paso 7, imagen 3 de 3
    • Locate the filament sensor.
    • Hold the filament sensor in place while unplugging the wiring connection.
    • Use caution because the wiring connections may be fragile.
    • Remove the filament sensor.
Conclusión
To reassemble your device, follow these instructions in reverse order. During reassembly, ensure not to tighten the socket head screws too tight.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 108
