Saltar al contenido principal
Protocol Vento Motor Replacement
Qué necesitas
  1. Protocol Vento Motor Replacement, Battery: paso 1, imagen 1 de 1
    • Grasp the tail end of the drone where the lip of the battery protrudes.
  2. Protocol Vento Motor Replacement: paso 2, imagen 1 de 1
    • Pull away from the drone to remove the battery.
    • Do not attempt any repairs or replacements before removing the battery from the drone.
  3. Protocol Vento Motor Replacement, Propeller: paso 3, imagen 1 de 1
    • Place a prying tool under the base of the propeller.
  4. Protocol Vento Motor Replacement: paso 4, imagen 1 de 2 Protocol Vento Motor Replacement: paso 4, imagen 2 de 2
    • Use a moderate amount of force to pry the propeller out of its base. The propeller should pop off.
  5. Protocol Vento Motor Replacement, Motor: paso 5, imagen 1 de 1
    • Unscrew the 4.9mm Phillips #000 screw that is located at the end of the drone's arm.
  6. Protocol Vento Motor Replacement: paso 6, imagen 1 de 2 Protocol Vento Motor Replacement: paso 6, imagen 2 de 2
    • Hold the base of the arm while gently pulling the motor cover away from the arm.
    • Do not pull too hard because there are wires attaching the motor to the drone. Do not sever the wires.
  7. Protocol Vento Motor Replacement: paso 7, imagen 1 de 2 Protocol Vento Motor Replacement: paso 7, imagen 2 de 2
    • Gently pull the motor out from the plastic cover.
    • Do not squeeze or pull too hard, as to not damage the motor connection.
  8. Protocol Vento Motor Replacement: paso 8, imagen 1 de 2 Protocol Vento Motor Replacement: paso 8, imagen 2 de 2
    Herramienta utilizada en este paso:
    • The motor’s blue and red wires are secured via a white clip. This clip is inserted into a slot in the drone’s leg.
    • Grasp the clip’s edges with a pair of tweezers and pull outward.
    • Do not pull directly on the wires, as to not separate the wires from the clip.
Conclusión
4 personas más completaron esta guía.
Maria Larcomb
Miembro Desde 02/15/18
926 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S1-G2, Leahy Spring 2018 Miembro de USF Tampa, Team S1-G2, Leahy Spring 2018
USFT-LEAHY-S18S1G2
Miembros de 4
6 Guías creadas
2Guía Comentarios
Please send me motor description
suresh virji - Contestar
send me protocol vento motor
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 757
