Introducción
This guide will demonstrate how to remove and replace the front camera on the Protocol Vento drone.
  1. Grasp the tail end of the drone where the lip of the battery protrudes.
    • Grasp the tail end of the drone where the lip of the battery protrudes.
  2. Pull away from the drone to remove the battery.
    • Pull away from the drone to remove the battery.
    • Do not attempt any repairs or replacements before removing the battery from the drone.
  3. To get into the drone, twelve total screws need to be removed:
    • To get into the drone, twelve total screws need to be removed:
    • Ten 5.7mm Phillips #000 screws from the bottom of the drone body.
    • Two 4.5mm Phillips #000 screws at the front of the drone.
    • It is not necessary to remove the four screws on the arms of the drone.
  4. Flip the drone over and lift off the top plastic shell of the drone. Flip the drone over and lift off the top plastic shell of the drone. Flip the drone over and lift off the top plastic shell of the drone.
    • Flip the drone over and lift off the top plastic shell of the drone.
  5. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  6. Remove the foam adhesive pad located on the Wi-Fi transmitter board. Remove the foam adhesive pad located on the Wi-Fi transmitter board.
    • Remove the foam adhesive pad located on the Wi-Fi transmitter board.
  7. Pry the gold Wi-Fi antenna connector, located under the previously removed foam pad, away from the Wi-Fi transmitter board to disconnect it. Be sure to only apply force to the gold connector and not the black wire attached to it, as the connection between the two is very fragile.
    • Pry the gold Wi-Fi antenna connector, located under the previously removed foam pad, away from the Wi-Fi transmitter board to disconnect it.
    • Be sure to only apply force to the gold connector and not the black wire attached to it, as the connection between the two is very fragile.
  8. Remove the two 3.8mm Phillips #000 screws from the Wi-Fi transmitter board.
    • Remove the two 3.8mm Phillips #000 screws from the Wi-Fi transmitter board.
    • Be careful with the delicate ribbon cable attached to the camera.
  9. Disconnect the white clip that connects the four colored wires (black, orange, red, blue) to the motherboard.
    • Disconnect the white clip that connects the four colored wires (black, orange, red, blue) to the motherboard.
    • Be sure to pull only on the white clip, as to avoid damaging the wires.
  10. Gently pull the black wedge away from the main board until it shifts to a stop. You will feel it slide out, then stop. The black insert acts as a wedge to keep the ribbon cable attached to the board. The wedge needs to be jostled loose before the cable can be removed.
    • Gently pull the black wedge away from the main board until it shifts to a stop. You will feel it slide out, then stop.
    • The black insert acts as a wedge to keep the ribbon cable attached to the board. The wedge needs to be jostled loose before the cable can be removed.
    • Lightly pull the ribbon cable away from the connector.
  11. Remove the two 4.9mm Phillips #000 screws securing the camera to the front of the drone body.
    • Remove the two 4.9mm Phillips #000 screws securing the camera to the front of the drone body.
  12. Lift the camera holder and the camera up and away from the drone. Lift the camera holder and the camera up and away from the drone. Lift the camera holder and the camera up and away from the drone.
    • Lift the camera holder and the camera up and away from the drone.
Conclusión
3 personas más completaron esta guía.
Equipo
USF Tampa, Team S1-G2, Leahy Spring 2018 Miembro de USF Tampa, Team S1-G2, Leahy Spring 2018
USFT-LEAHY-S18S1G2
4 Miembros
6 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 7
Todo El Tiempo: 190
