Saltar al contenido principal
Protocol TerraCopter EVO Front Wheels Replacement
Qué necesitas
  1. Protocol TerraCopter EVO Front Wheels Replacement, Propellers: paso 1, imagen 1 de 1
    • Using a Phillips #0 screwdriver, remove the four screws connecting the propellers to the device.
  2. Protocol TerraCopter EVO Front Wheels Replacement: paso 2, imagen 1 de 2 Protocol TerraCopter EVO Front Wheels Replacement: paso 2, imagen 2 de 2
    • Hold the propellers gently and pull the propellers out of the drone .
  3. Protocol TerraCopter EVO Front Wheels Replacement, Front Wheels: paso 3, imagen 1 de 3 Protocol TerraCopter EVO Front Wheels Replacement, Front Wheels: paso 3, imagen 2 de 3 Protocol TerraCopter EVO Front Wheels Replacement, Front Wheels: paso 3, imagen 3 de 3
    • Use a plastic opening tool or a spudger to separate the drone's cover from the body of the drone.
    • Remove the connector of the drone body and the back wheels using a plastic opening tool.
  4. Protocol TerraCopter EVO Front Wheels Replacement: paso 4, imagen 1 de 2 Protocol TerraCopter EVO Front Wheels Replacement: paso 4, imagen 2 de 2
    • Use the opening tool to separate the drone's body from the drone's shock absorber.
  5. Protocol TerraCopter EVO Front Wheels Replacement: paso 5, imagen 1 de 3 Protocol TerraCopter EVO Front Wheels Replacement: paso 5, imagen 2 de 3 Protocol TerraCopter EVO Front Wheels Replacement: paso 5, imagen 3 de 3
    • Hold the wheels gently then pull it out of the drone's lower board wheels connector.
    • Repeat the same step for the other front wheel.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 134
